Font Issues
Font Issues
Font Issues
SW09 Pro x64, SP3.0, FX580
I have a font issue and it's driving me crazy.  We are trying to adopt the use of tagging dims for inspection with the oval functionality SW provides.  When we mark a dim for inspection the tolerances on the dims shrink about 25%.  We also dual dim, and square brackets will also change in the same manner.  I have been through all the Document Properties that I can think of, but can't see anything that would contribute to this scaling issue.
Any ideas?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
RE: Font Issues
I doubt that there is anything that you can do.  I believe SW automatically scales them down to fit them inside of the oval. Are they too small to read?
RE: Font Issues
Not too small to read, just small enough to not look proper.
RE: Font Issues
I've never used that function. Can you scale up the oval?
RE: Font Issues
No, the oval automatically adjusts its own size as required.  At previous jobs I never ran into this issue, making me think it is some setting that I am not aware of.  I've even tried several different fonts (Arial, Arial Unicode, Century Gothic, etc) and TruType fonts with no effect.
RE: Font Issues
We are running 2008 sp5 and we don't have this issue.  The dimension text remains the same size w/ or w/o the oval.  Does 2010 have this issue?
RE: Font Issues
Will this help? Document Properties - Dimensions - Tolerance (located at the bottom of page) - Font.
RE: Font Issues
Felix, that was the first place I checked. glasses
RE: Font Issues
What about on the Other tab in the Dimension Property Manager?
RE: Font Issues
My co-worker has the same spec'd computer as I do (purchased identically) and his font is not changing, but the square brackets used in dual dimensioning are getting smaller.  I need to see if others are observing the same thing, just don't have the time to dig much deeper at the moment.
Felix7502, both have been checked, and not sure why/how you can enable one and it won't enable the other... but that's an animal for another day.
RE: Font Issues
MM ... just for the hell of it, install a copy of your co-workers reg file to your computer. Copying their Windows/Font folder might also be worthwhile.
