Change Axis of Rotation
I am having a problem changing my axis of rotation of a
shaft operation. I rotated my geometry using shaft operation. But I need to move the axis up and use this as
the new axis of rotation. Is there a way to do this in
Catia V5?
Thanks much
RE: Change Axis of Rotation
I'm not sure I understand what you mean by 'move the axis up'. Is your axis part of your sketch, or did you select a line as your axis? Is the new axis you need coincident with your former axis? Remember that any axis can be seen as a neverending line.
Also, have you tried to do a simple replace?
Christian Bunes
http://www.plastal.com/
