adding a layout tab per template with VBA
I'm trying to add a layout tab to a drawing from a template.
I've already got it to create the drawing from a template
as shown below, but how do I add more layout tabs with the same template?
Here is what I have to create the drawing from the template
ThisDrawing.SetVariable "SDI", 1  'Single Document Interface or MDI
Dim templateFileName As String
templateFileName = "K:\CAD\CAD Features\Templates\TB-STANDARD.dwt"
ThisDrawing.New templateFileName
ThisDrawing.SetVariable "SDI", 0
Pt1(0) = 0: Pt1(1) = 0
ThisDrawing.ActiveLayout = ThisDrawing.Layouts("STANDARD TITLEBLOCK")
and I know that I can add a layout using
Set objLayout = ThisDrawing.Layouts.Add(LayoutName)
I just can't quite get the whole thing together to add the layout with the template.
Any help would be appreciated.   THANKS
RE: adding a layout tab per template with VBA
From the top toolbar choose "INSERT"<
From the pulldown, choose "LAYOUT"<
From the flyout, choose "NEW LAYOUT"<.
I pulled a torpedo level out of the bag and put it on the frame rail and the senior year intern engineering student exclaimed "Ooo...what is that?!".
Also, from the command line, type "LAYOUT"<
At the command line, type "N"<
Then type the name for the new layout.
