metric trapezoidal thread help
we make a dual post automotive lift that is a screw lift. the screw is a 43.3 x 6mm pitch screw. the material is 1018 steel and the thread is roll formed. the nut that is used is made from nylatron and the thread are machined on a cnc lathe.
could someone please tell me the proper fit to be used for these parts to work properly. we have porblems from time to time with the lifts not working properly in our test area and i just would like to make sure that the fit between the two parts is correct.
any help would be appreciated.
