SWx to Step export issue
I have a part that has about 50 features. among them there is a feature linear patterned (about 50 instances). then this linear pattern is mirrored. Later, both pattern and the mirror are patterned about 25 instances.
The part was 35 MB. I used eco squeese and its now 7 MB.
I cant export to STEP. It simply freezes SWx. I have tried on 2-3 computers, the problem persists.
Any tips is appriciated.
BT
BT
RE: SWx to Step export issue
If you can, try parasolid, open in SW and then export to STEP.
Also, can the mirror feature be made after the original pattern is patterned? It probably won't make a difference, but is worth a try.
Will try the mirror later in the tree. Will keep posted.
Thanks for your comments.
BT
