Transformer 10 MVA 22kV/6.9kV has been shutdown.
- Bucholz device activated
- Pressure Relife Device activated
and too much oil spill to outside of transformer from pressure relife device.
After incident ,We have checked
Insulation of winding and Earth = 0 Mohm
Insulation of HV and LV winding  = 0 Mohm
-Downstream (6.6 kV SWG)
Differential and Buchholz trip
-Upstream (22 kV SWG)
intertriping trip and Earth Fault
So anyone can suggest what problem happen with my transformer ?
and what can i do ?
Thanks you
RE: Transformer 10 MVA 22kV/6.9kV has been shutdown.
Your transformer died a violent death.  Take an oil sample, but start making plans to get it shipped out for repair.
If you're lucky, it only needs a rewind.
Jed-
dpc has it correct.  Your transformer has died.  It sounds like interwinding and winding to ground failures.  this is serious stuff.
There is only a tiny possibility that repairs will be simple. 99% chance it will have to go away for repairs.
It is likely that your oil sample when analyzed for dissolved gases will show products that indicate high intensity discharge within the oil.
The fact that BOTH windings show zero ohms to ground discounts the possibility of an easy fix like a bad bushing that could be replaced on site.
old field guy
I would be figuring on a big bill. If you're lucky you might salvage the core although with a double winding ground fault that doesn't look too promising. New transformer will likely cost in the order of £150k - £200k. Ouch. smile
Hmm, would a DGA sample even show anything after the releif lifted? I would think the results would be pretty worthless.
6.9kV huh? That might be a hard one to find, where are you located?
Also, if you have micro-processor relays or some type of digital fault recorder, I'd make sure to download all pertinent event reports and fault data for further analysis.
Zog--
Most of the reliefs I'm used to seeing seat off (mostly) after dumping the pressure. I think a DGA would still be good. However, if the oil was exposed to atmosphere for very long, it would be less so.
A sample might also show suspended carbon and other products of the fault.
old field guy
Yes they do but I would think the rapid decrease in pressure would "degas" the oil.
Transformers normally sit somewhere near atmospheric pressure so degassing shouldn't happen too quickly. Anyway, it's not the ppm values per se, but the concentration ratios between gases and the long term trends which tell the real story. After it goes bang all bets are off, DGA is a preventative maintenance tool and it went bang anyway.
Thank you everybody !!
I have checked the record from digital relay.
T observed that phase B loose of the current in that fault time and high rush current in another 2 phases.
I plan to sent it to manufactere soonest.
Young Engineer.
Jed--
If you get a chance, follow the transformer back to the factory and view the work.  It's good experience.
Good luck!
old field guy
