Dimension Match Properties
Is there a dim match properties command?
I have applied several tol, # of dec, dual units etc to a dim on a drawing. I have another dim which needs the same format. Is there a match the properties command?
BT
BT
RE: Dimension Match Properties
You could have done with Ctrl-select all the dimensions and applied format once.
Alex
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
