Curvature of airfoils
Does anyone know whether there exists a standard way, or any other method, to smoothen the curvature of airfoils without changing the geometry too much?
Thanks in advance,
Gerrit
Thanks in advance,
Gerrit
RE: Curvature of airfoils
I want to slightly change the nodes, especially with respect to eachother, to smooth the curvature, without really changing the geometry too much.
...but not by hand, so I'm looking for a method...
Have you double checked the source data and your transposition of it?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
(The source data is whimsical, that's why)
The point is that continuity in the second derivative doesn't assure smoothness in the curvature at all, it just assures you continuity (and I wonder whether continuity in the 3rd derivative will... so, some kind of filter or smoother has to be applied).
if you know the airfoil section you wanted, like from NACA data, it'd be alot easier ... but then you wouldn't be fussing with this stuff ...
Exactly how rubbish are the points you have? Do you have a high density of noisy points, or just a few points that need to be joined up gracefully?
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I'll have a look at octave, anyway I use to use fortran to to this stuff.
And yes, I could do curve fitting, using whatever kind of tool, but I'm looking for a reasonable objective criterion to do local fitting automatically by some fortran code.
Even though the density of the nodes I happen to have now is rather low, I'd prefer a day of coding in stead of starting up some curve tool (having to learn it) and doing the process by hand.
That is why I asked for a method. With a method I meant a mathematical criterion to exclude or deviate or include points in your local fitting scheme to be able to automate the task. To do so, you need to filter the whimsical curvature data and use that as a goal within a maximum allowed deviation from the original geometry.
Obviously, if you do it by hand, and you pull some Beziers, it's straightforward indeed and a natural fit with Beziers is an option, but I'm not looking for that option.
Anyway, I'll look at octave, because I've heard more positive things about it.
Gerrit
If the latter than you may need to change approach as you work around the perimeter.
Cheers
Greg Locock
1. Far better computational convergence at los Reynoldsnumbers in programs like Xfoil.
2. Easier to convert it into a CAD surface automatically.
When you talk about noisy data, you probably refer to measurements from an already manufactured surface, that's not the case.
Gerrit
Ultimately it's NURBS, the mathmatical basis for all "Computer Graphics" today.
google for Xfoil or Profili2, IIRC Xfoil can do smoothing of airfoil coordinates.
Michael
Thanks for all your answers.
@rb1957:
No, I didn't mislead you.
@sreid
Nurbs is about the worst choice for aerodynamic surfaces, the curvature of any automatically generatied nurbs are like the rocky mountains, even if they look nice smooth and shiny at first. A good surface is defined by single bezier surfaces.
@mihumihu
What are these programs about? I found profili, but not IIRC
Gerrit
it sounds as though you are using synthetically generated profiles, in which case that is not the problem.
Cheers
Greg Locock
IIRC = If I Recall Correctly. Not a software program, just a common shorthand.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
