Move detail view
Move detail view
Hi
Does anybody knows if it's possible to move a detail view (simple stepped section line)
from one parent view to another parent view. I have the same geometry in both views
When I delete a parent view my detailed view will be deleted as well.
I know it's possible to select view boundary on the section views parent view and make the parent view very small so all the lines in the view will be hided and then move the section line to another view, but I would prefer a methoed without all these "empty" views.
Hope someone has a solution.
RE: Move detail view
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
If the base view has section lines you can display the label on the section view as you may wish (or not) but by editing the style it is possible to set the section lines themselves to No Display.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Thank you for your kind support.
Best regards,
Anders
