Double Precision and Modules
very new to Fortran but have written the code attached. However it doesn't seem to run with double precision unless I use the old style method of writing 0d0 and implicit double precision at the top of the subroutines. I have tried to use a module and declare everything in it to be double precision but this doesn't work.
When it runs with double precision the final answer is 2.828427124751.
Have I made some really obvious error or why does this not work? I don't want to use the old Fortran methods so any help is really appreciated,
Rich
Rich
RE: Double Precision and Modules
integer, parameter :: dbl = selected_real_kind(p=7)
Try
integer, parameter :: dbl = selected_real_kind(1.D0)
and specify all real constants like 0.1 as 0.1_dbl
