4" sqaure aluminum tubing
i had to weld 2 6"x14" peices of aluminum plate on the tubing and now the tubing has a slite bananna bend to it how should i go about getting this out so its straight ? it is '20ft long and is going to be a trial for concrete
RE: 4" sqaure aluminum tubing
You could make a "straitening press" using a hydraulic jack if you have a way to counter act the force by securing the other section of the tubing. Use a tight string to find where the bend is and where it is straight.
I would think that the bend is very localized so you would only need to concentrate on the area near the welds.
Depending on the material, if you someone with a lot of structural weld experience there is a method heating the area and then selectively cooling one side to get the material to pull back in line.
If you have to do this again you can pre-bend the tubing the opposite way and then the welding will pull the tube straight. Again this takes experience on the part of the welder and/or shop.
Another method I have read about but do not have any hands on experience with is a vibratory system that is applied during the welding to relieve stresses before they pull the tubing.
did you preheat the aluminum before welding
an other sugestion if you have access to a press.
mount/support the tubing assembly on each end with steel supports(steady rest or horses). heat the assembly, then press in the center of the bowed section with a press.
use a dial indicators with plenty of travel to verify
the amount of travel or verify with a straight edge.
