Factored weld resistance of 1/4" fillet weld with stainless
Would any one know what is the factored weld resistance of a 1/4" fillet weld between stainless Grade 304 material?  Where would be a resource I could look this up?  What electrode classification number is generally used?
RE: Factored weld resistance of 1/4" fillet weld with stainless
Google " welding stainless steel " .  A resource that should pop up is a NIDI publication that has all you want including the strength listings for all types of weld rod and processes.
rmw
Recommended electrode for 304 to 304 welds is AWS A5.9, ER308L, not that this is the only electrode that can used.
"Saving the World One Beam at a Time"
