Visibilities->Clip
Visibilities->Clip
Visibilities->Clip
Does anyone know of any reason why the Visibilities->Clip slide bar would be disabled?
It's under "View->Advanced->Visibilities" in 2000i.  It did work at one time.
RE: Visibilities->Clip
Hi.  Did you change your graphics card recently?
You may also want to check your config.pro.  There are a couple of settings that you may want to check out.
Good luck.
make sure your config.pro setting is opengl and not win32_gdi.
