Uninstalling Solid Edge V18... without disc
I need to uninstall solid edge v18 but no longer have the disc that is required for unistalling; any suggestions?
RE: Uninstalling Solid Edge V18... without disc
Add / remove programs from the control panel doesn't work?
No, it asks for the installation disc
Just delete the installation folders, then clean up any debris using a registry cleaner. I use CCleaner from http://www.ccleaner.com/
Do you have a newer version of SE on disc?
If so, it should have a clean-up utility on it.
