bonding fiberglass to copper underwater
My 60 year old swimming pool houses the filter in a 14" diameter copper pot that extends 26" below ground. The soil here is decomposed granite which is quite acidic and eats copper. The copper pot has developed many pinholes and is ready to fail. I propose to line it with one or two layers of 30 mil fiberglass sheet that I have. What would be a suitable bonding sealant given that I don't dare do a lot of sanding of the surface and do not want to drain the pool given our cronic water shortage?
RE: bonding fiberglass to copper underwater
If you can't do that, you might have some luck with marine caulks, some of which will cure underwater. The first one that comes to mind is 3M #5200 adhesive/sealant, which is available in small tubes at Wal-Mart. Use dropcloths and gloves; it doesn't come off easy, even before it cures.
Mike Halloran
Pembroke Pines, FL, USA
