Nonlinear static -- theoretical formulation
Hello
I would like to know what is the nonlinear formulation for nastran sol 106?
Logically, in statics you should have
Kij Uj + Kij UjUk + Kijkl UjUkUl=Fi
It seems not to work correctly when using shell elements...
Is the formulation taken correct or is there a parameter to adjust in the bulk?
I thank you for advance
Sincerely yours
