Hollow Ball Valve
Hollow Ball Valve
Hollow Ball Valve
Have anyone experience hollow ball ball valve? If it is hollow ball, is there any equation to calculate the wall thickness of the ball?
RE: Hollow Ball Valve
Ummmmm - if it was not "hollow", how would it work ?
The ball normally has a hollow cylinder for the fluid path.  It is common for ball valves to have an internal diameter reduced one line size smaller than the end connections.  The alternative is full port or full bore.  The ball rotates to close thus shutoff the flow.  Let me know if I am missing something from the question.
There's no theoretical reason you couldn't make a hollow valve ball.  If you're that severely weight- constrained, you might consider a butterfly valve instead.
Given that nobody stocks ball valves like that, it's custom, and the wall can be as thin as you want it. ... remembering that you'll be paying for machining time.
If you want to make it really thin, you need to consider the forces from the valve seats and the stem in addition to pressure considerations.  Some seats apply a lot of force and/or expect the ball to not deflect much.
Mike Halloran
Pembroke Pines, FL, USA
Thanks for all your reply. Butterfly valve is not piggable. In order to reduce the cost people uses hollow ball to reduce valve weight especially for stainless steel ball. What I mean by hollow is that the space between the bore and the sphere is hollow.
Hollw balls are made by casting the round part of the ball, and the internal part is also cast spherical.  The flow path is made by inserting a piece of piep (cylinder anside the ball and welding both ends at the opening.  the wall thickness of the cast part of the ball is usually thick enough since it must be thick enough to aloow the molten metal to flow though the mold. Check the weld size and wall thickness of the cylindrical pipe as well.  Use manual calculations, FEA, and TESTING to verify both the design and manufacturing process makes a useable part.
