DeLaval type L,M,P,T Split Case pump Axial thrust
These large split case pumps have plain "babbit" journal bearings front and rear. But in the rear in addition there are Ball type thrust bearings. The O & M manual is very vaigue on this subject.
We have pumps that Oscillate in and out axially up to 1/2".
The thrust bearings have been replaced but some how they continue to move in and out freely, inside the bearing housing i assume.
What is alowable or typical of a splitcase pump shaft?
Has anyone dealt with this problem?
Tim Wood Mechanic
Tim Wood Mechanic
RE: DeLaval type L,M,P,T Split Case pump Axial thrust
Mrs. Carolyn B. Smith, Repair Engineer
Siemens Demag Delaval Turbomachinery, Inc
Energy Sector
840 Nottingham Way
Hamilton NJ 08638, United States of America
Tel: +1 (609) 890-5185
Mobile: +1 (609) 221-7932
mailto:carolyn.smith@siemens.com
We see this axial movement regularly on pumps of this configuration. I am often amazed at how little movement we are able to get when we shut the pump down and thrust it with a dial indicator. A very small amount of axial movement on a running pump looks like a lot more than it is.
I would review the bearing selection and arrangement. Make sure that the bearing is properly constrained from axial movement. For a back-to-back 40 degree angular contact thrust bearing pair, we would normally limit the outer race movement axially to about 0.005 inch in a large between bearings pump. Review the piping configuration on the suction side for anything that would throw uneven flow to the impeller eyes. Review the operating conditions in light of the suction specific speed to make sure you are running at an acceptable rate relative to BEP. Of course, you should consult with the pump manufacturer. They may have experience with this particular model that explains the problem.
In the worse case scenario, we have resorted to changing the impeller eye wear ring geometry slightly to induce a stable thrust in one direction. But, this would have to be done with extreme care.
Johnny Pellin
