Flexibility factors of trunnions on elbows - analysis methods
Hi All
I have been asked to perform FEA on trunnions on elbows and develop flexibility factors for incorporating into CAESAR calculations.
I know that the available literature focuses more on SIFs than flexibility, as that is generally of more importance. However, in my particular analyses the trunnion and elbow are directly beneath nozzle of a compressor, so any added flexibility in the system is important because of the loadings it will place on the compressor nozzles. I know that there is current literature that I can use to address the analysis, for example:
mydocs.epri.com/docs/public/TR-107453.pdf
However, it would be great if someone with experience could confirm for me whether FEA of my particular system would produce significantly more accurate flexibility factors than the application of previous analyses. The suction lines are generally NPS 72" with a wall thickness of 19mm. One end of the elbow will also be potentially connected to a flange, which will also produce a stiffening effect! I'm not sure what the discharge line wall thicknesses are off the top of my head, but they are generally NPS 56"
I am a junior piping designer at a company, and currently starting my BEng final year project in mechanical engineering, so apologies for any glaring errors in my post!
Any help is appreciated.
Thanks.
Thanks.
RE: Flexibility factors of trunnions on elbows - analysis methods
Boiler and Pressure Vessel engineering - Lifting Trunnion Common ... 13 posts - 8 authors
I was curious about your post so I spoke directly with CodeWare today via email and they said that COMPRESS has no lifting trunnion calculations and has no ...
www
Trunnion Calculation - [ Translate this page ]Trunnion Calculation Hovedprosjekt for Aker Kværner ... faglærer Per Erik Thoresen fikk vi hovedprosjektoppgaven Trunnion Calculation ved Aker Kværner. ...
www.wollebak.com/trunnion/index.htm - Cached - Similar
[PDF] Forside hovedoppgave HiO - [ Translate this page ]File Format: PDF/Adobe Acrobat - View as HTML
Postboks 4, St Olavs plass. 0103 Oslo. Telefon: 22 45 32 00. Telefax: 22 45 32 05. HOVEDPROSJEKT. Oppgavens tittel: Trunnion Calculation. Dato: 14.05.2004 ...
ww
Pipe support stress analysis: trunnion, riser (stack) design: Pipemill Trunnion type pipe supports and vertical riser (stack) type supports may be analysed using Pipemill. Both calculation routines include the effects of ...
pipemill.com/pipe-support-stress-analysis.php - Cached - Similar
XLS] Ark1 - [ Translate this page ]File Format: Microsoft Excel
3, Avdeling for Ingeniørutdanning TIMELISTE FOR HOVEDPROSJEKT, 02 Feb. ..... 108, Oppgavens tittel: Trunnion Calculation, 5-May ...
www.
Northern Software Developments - Engineering Software networks. Up to 1000 piping elements. Trunnion. Piping trunnion stress calculation. Aligncal. Propeller shaft alignment calculation. ...
norsoftdev.com/ - Cached - Similar
