improving cavity Q by metal plating
I have a pretty large cavity (microwave heating experiment) that I am doing experiments in. It has to hold a high pressure (200 psi), so initially it was design out of steel. But now I find that the energy is not being absorbed so much in the load as I expected, but it is also being simultaneously absorbed by the cavity walls. I either need to plate the cavity walls with some higher conductivity metal, or make the entire cavity out of something like aluminum (not as strong).
My problem is that the process gives off nasty vapors, like sulfuric acid, etc. If I just plate the cavity inside with copper or silver, I am afraid that the acidic environment will cause it to blister/degrage in short time.
So, does anyone know some plating scheme that would give me a higher cavity Q, but uses metals that are relatively immune to acidic fumes?
I once remember silver plated waveguides, with a thin rhodium flash on the exposed surface, as being relatively tough. Any ideas like that?
Alternatively, has anyone experience of adding a reflecting surface plate inside of a large cavity? Maybe a thick (sacrificial) copper plate that would reflect microwave energy that could be hung inside of the larger steel cavity in strategic positions?
Rich
Rich
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
RE: improving cavity Q by metal plating
Copper is better than gold too.
Aluminum is only a little worse than gold and much better than steel too.
kch
Brush plating is apparently not designed for such a large surface area project, and the cost would be more like $10,000 with a less-controlled plating thickness afterward.
What's the operating frequency?
As an alternative to gold if that's not possible, I might consider using a silver or copper plate and coating it with a low loss tangent material like teflon for acidic protection. You would have to avoid coating the connecting surfaces. I believe there are commercially available microwave heaters that are constructed similarly.
I'm curious about the reflecting plate inside a cavity. Can you tell me more about what you are trying to do?
h
Scroll to the end of the list of pictures to find it.
