Attaching a rotating wire to a still one
What is the standard method for attaching a constantly rotating (>360) wire to a still one... is it even possible? Will everything still flow right?
I'm not afraid to ask this question even if it comes off as basic.
RE: Attaching a rotating wire to a still one
Slip ring. Like the brushes in an automobile alternator.
If it's a single  connection then it's possible to make the connection to the shaft end as well as a point on the circumference. A carbon brush of some form is the typical transfer.
If you can make one end spring-loaded and the wires are thick enough, a cup at one end and a point on the other would work reasonably well.
Dan - Owner
http://www.Hi-TecDesigns.com
