Heat treatment
Heat treatment
Heat treatment
I have a question regarding heat treatment of steel casting.
Is it acceptable/ok if a 9 hrs heat treatment chart shows an interruption - lets say 10 minutes?
Thanks in advance.
RE: Heat treatment
Please comeback with more details.
What is the material?
What part of the heat treatment was interrupted?
RE: Heat treatment
Assume 9 hours to be soaking times. A 10 minute interruption,might cause a drop in temperature of few 10's of degrees. Practically should not be a major cause of concern.
Learn the rules,so you know how to break them properly.
Dalai Lama
_____________________________________
RE: Heat treatment
Sorry for not reponse quickly.
The material is ASTM A487 Gr 10 Cl B.
Thanks all.
RE: Heat treatment
zhin,
You should indicate your heat treatment temperature and the variations in your specific case...
RE: Heat treatment
zhlin,
I have the spec with me,which specifies the austenitizing temperature as 1550F(845C), liquid media quenched to below 500F(260C) and then tempered at 1100F(595C).
Why have you gone for such a long austenitizing cycle ( I am assuming,as you have not mentioned)?
Dalai Lama
RE: Heat treatment
Dalai,
The part is 8", which was the heat treat time came from, I think.
Yah, per the spec, it should be cooled at liquid and then have temper per the spec.
So I am going to dig up more information.
Thank you!
K
RE: Heat treatment
The applicable AMS specifications discuss cycle interrruptions.  Usually the are allowed if they are minor and your Quality System has a procedure for handling them.
admin@heattreatforum.com
RE: Heat treatment
