High cycle valve
High cycle valve
High cycle valve
Hello all.
We have a bit of a pet project.  We are looking for a high cycle valve.  Right now we can only really hink of a cam driven full rotation valve.  Ideally, we would like to use a solenoid valve, but will eventually need something at 1000+ RPM, so I don't know how realistinc that is.  I know it is not too much deail, but any ideas?
RE: High cycle valve
You need to provide the fluid type, flow volume, operating pressure, number of ports and flow path. Knowing the opening and closing time required is helpful. If you require a life in number of cycles post that also.
Ed Danzer
www.danzcoinc.com
www.dehyds.com
