County of Los Angeles Allowable Shear Limitations
County of Los Angeles does not allow more than 200 lbs./ft for 3/8" like the CBC allows.  PC'r told me to refer to the County's code book, which I do not own and as an architect who doesn't do a lot for engineering don't want one.
Does anyone have the County of Los Angeles' allowable shear loads table I can get for a correction?
RE: County of Los Angeles Allowable Shear Limitations
Hey, Thanks but I found code, now just need to adjust my SP Sched
I guess I'm just getting too old.  I don't know what the hell you are talking about.  Allowable shear limitations?  200 pounds per foot for 3/8"?  What is that all about?
And secondly, what is your SP Sched?  Would you be totally offended if I asked you to translate all of that into English?
BA
I think he is talking about shear wall allowable load for 3/8" plywood.
Must be archispeak.
curtschultz, should should be able to find the latest copy of the LA County Code in a Library such as the Los Angeles Public Library or the Los Angeles Law Library.
