Wiring diagram Nissan Primera 1993
Could someone give advice me. I have problem with headlights on my Nissan Primera diesel. Thanks Michael
RE: Wiring diagram Nissan Primera 1993
describe the problem and I might be able to point you in the right direction, headlight circuits are usualy pretty standard
It lights only the left head-lamp. The right one is not shining, neither low beam or high beam. The fuse and relays seem to be good. But I don´t know what else should be checked. Michael
sounds like a ground wire, high and low beams both use the same wire for ground.
you have checked to make sure it is not the bulb right?
The bulb is okay. But the ground wire could be good idea, because the headlight is shinings sometimes and sometimes not. I´m in work now, but I checked it in the afternoon. Thanks
