Welder possibly used 308 filler on 16Ga sheet metal 316 part
Are there any detectable visual differences between the two filler rods after the part has been welded?
RE: Welder possibly used 308 filler on 16Ga sheet metal 316 part
The reason is that the general corrosion resistance of 316 SS is better than 304 SS. If you put a sample of each outside in certain atmospheres the 304 SS will show staining and spotty rust long before 316 SS.
It is a guard panel on a pharmaceutical labling machine. Not structural, only ambient temperatures.
It should be ok since they normally don't use harsh cleaners on this part of the line and they wou;d keep it wiped down.
Cleaners with Chlorine will tend to rust 304 SS a lot quicker that 316 SS. Normally used SS cleaners will not cause any problems.
