gasket material
gasket material
gasket material
hi all,
Can any tell me the properties of gasket material(soft steel or iron) at 65 deg.
I need modulus of elasticity, poisons ratio, density, thermal conductivity and expansion
thanks
RE: gasket material
Fahrenheit or Celsius?
Fegenbush
RE: gasket material
what type of steel?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: gasket material
I think the simplest answer is to go to Flexitallic's website or give them a call.
RE: gasket material
The material normally used in gaskets is referred to as ARMCO Iron.
Depending on your end use of the material you could get by with using the values for AISI 1010 steel.
Are you considering this for a gasket and if so, the need values for calculation of gasket seating stresses are in the code books or the gasket manufacturers catalogue.
