Tri-clamp fittings standards
Hello everybody!
Does anybody know are there some compatible tri-clamp standards among the below mentioned which could be assemblied with each other or they are all non-compatible?
ASME BPE-2002
BS 4825 Part 3 / ISO 2037
DIN 32676
DIN11864-3
ISO 2852 and SMS 3017
SMS 3008
ISO 1127 Schedule Pipe Size
BS 6362 Schedule Pipe Size
ASTM A312 Schedule Pipe
Any help will be greatly appreciated.
ASME BPE-2002
DIN 32676
DIN11864-3
SMS 3008
RE: Tri-clamp fittings standards
There are a number of Tri-Clover knock offs that do just as good a job as Alpha-Laval.
Otherwise, there is some cross between metric and standard sizes, but very few. Most of your list are different threads. On the flip side, there are a large number of commercially adapters which will allow for the change of standard.
worst case you'll have to make your own.
http
http://www.alibaba.com/showroom/Tri_clover.html
http
I mean could the parts from the attahced file be assemlied as one union if one of them made acc. to DIN 32676 and other acc.to ASME BPE-2002 for example?
Where you may run into issue is the associated tubing diameters. Keep your ID's continuous and match your gasket to that opening, and you should be fine.
But I have some doubts that the grooves for the gaskets in differens standards have the same diameter. Please see the ppt.
If ID projections are not an issue then you can very well use one standard TCs for any standard piping.
Thank you!
