VBA Catia: CATParts in a CATProduct considered as Product Objects
Evening all,
I've written a bit of VBA code to play with CATParts for the automation of copy/paste bodies and operate transformations such as splits etc.
When i try to adapt this to a CATProduct i cant seem to be able to get the Part Porperties/Methods i had in my former code.
Let's say i have a CATProduct made of a CATPart and a sub-CATProduct (made of 4 CATParts itself).
This is the beginning of my code:
Set partdocument1 = CATIA.ActiveDocument
Set product1 = partdocument1.Product
Set part1 = product1.Products.Item(1)
Set subproduct1 = product1.Products.Item(2)
Set subproduct1_part1 = subproduct1.Products.Item(1)
Set subproduct1_part2 = subproduct1.Products.Item(2)
Set subproduct1_part3 = subproduct1.Products.Item(3)
Set subproduct1_part4 = subproduct1.Products.Item(4)
All the above end up being Product Objects even though they clearly have nothing under them apart from product1 and subproduct1 (e.g. part1.Products.Count = 0). I have tried ActivateShape and DesignMode with no success.
Could you help me getting hold of the actual Part Properties/Methods when i've reached a CATPart (i.e. get to Bodies, ShapeFactories etc...)? This way i could navigate in my tree and perform operation within the Parts i want to modify.
The way around it would be to grab the CATParts full name and open them in a new window, save, close and update product1 but i'm sure there is a smarter way to do it within one single window.
Thanks for your support !
RE: VBA Catia: CATParts in a CATProduct considered as Product Objects
Which program and version are you working in?
Microsoft Excel 2000
Catia V5 R18
________________________________________
My Catia tree looks like this:
product1
   |_ part1
   |_ subproduct1
        |_ subproduct1_part1
        |_ subproduct1_part2
        |_ subproduct1_part3
        |_ subproduct1_part4
AeroBouquito
I'm not familiar with CATIA.  Is this something you accessing through an Excel add-in, pulling in files, or are you trying to reference another program.
The methods you want might not be available without setting the reference library in the VBE.  From the visual basic editor select TOOLS > References > then see if you can scroll down and find a reference library for CATIA.
If this happens to be the case then, after setting the reference library, you should be able to dig through the object browser and find what properties and methods are available to you.
-JTBorton
Well, You can try banging your head against the wall, but you just end up with lost-time injuries and damaged equipment. [M. Passman]
Sorry about the grammar of that second sentence.  That should be a question,
"Is this something you are accessing through an Excel add-in, pulling in CATIA data files, or are you trying to reference another program through the Excel environment?"
-JTBorton
JTBorton,
Thanks for your reply. I had all those references set already and had tried to navigate through the object browser. My tool work perfectly well with CATPArt files but it's only when trying to access CATPart via a CATProduct that i cannot access the correct methods and properties, as CATProducts children are by default considered as CATProducts as well(with different methods and properties from CATParts).
I think im gonna go banging my head against a wall then !
If anyone else has a solution to my issue, please let us know !!
Thanks !
... sorry i forgot to answer your question in the end.
Yes, i do run my VBA script from Excel ... and it goes to read and control an open Application/Window of Catia V5.
I am not familiar with CATIA either.  However, I am quite conversant with the objects, properties, methods concept use in VBA.
Does the CATIA Object Model have an object for Part?
If so, what are some of it's properties & methods?
AeroBouquito
Bring up VBA in Excel and hit F2. This will bring up the object browser.
If CATIA has exposed any public properties/methods for you to work with, you should be able to see them here.
Note that you may have to add a reference to CATIA under Tools->References
Tim Grote - The Irrigation Engineers.
www.irrigationengineers.com
Thanks for your replies. To answer your questions, yes i have added the References associated to Catia V5 in my Tools/References and can see the methods/properties available for Catia objects through the Object Browser within VBA.
When i run the code step by step i can clearly see my objects being dealt with.
Catia libraries include 2 disctinct Objects for CATParts (Part Objects from Catia Library) and CATProducts (Product Objects from Catia Library). Each of those have different methods/properties. The issue is that for some reason, a Product Object child "HAS GOT TO BE" a Product has well where obviously at some point it will be a Part.
To make some analogy, a CATProduct is like a folder where a CATPart is like a file. I want to dig into my hierarchy of folders to find my files and work on them (products leading to parts). You wouldnt want a file to be considered as a folder just because it's one of the folders children.
I also tried to force the format of both objects but it would lead to a type mismatch, eg:
Dim myProduct as Product
Dim myPart as Part
myPart = myProduct.Products.Item(1)  <--- type Mismatch
Any thought ?
Thanks.
AeroBouquito:
It may be that because you're using objects you need a set statement, like so:
Dim myPart as Part
set myPart = myProduct.Products.Item(1)  'note the 'set'
If that doesn't solve it, it may be that the products collection isn't returning a 'Part', but something else. See if it bombs if you define myPart as a Variant.
Hello atook,
I actually forgot to write down the "Set" in my former post. Apologies as i was doing this already in my code. This returns a Type Mismatch error.
I've just tried as you suggested to "Dim myPart as Variant" and the error went away but Part1 was then considered as a Product once again. Grrrrrrrr.
Yes, the return item on a products collection should be a product.
Again, I'm not familiar with the object model, but I've an idea you need to be looking for a collection of parts withing a product. Something along the lines of:
Dim myPart as Part
set myPart = myProduct.Parts.Item(1)  'note the 'Parts'
