breaking in of pump
breaking in of pump
Good day people,
If the manufacturer does not specify, for whatever reason, do new pumps or newly refurbished pumps require a "break-in" period? If it's fixed speed, how would you do this as the pump would run flat out once its online..and..if it's variable speed, do you run it at a lower speed?
RE: breaking in of pump
"If experience was always the only factor, how would we get to the moon?"
http://www.piping-designer.com
