Calculate weld shrinkage?
Does anyone here calculate weld shrinkage?
Yes I know there are a bazillion factors. =)
There was good info here but no numbers:
http://www.eng-tips.com/viewthread.cfm?qid=142412
My specific problem:
I Have a base plate and a 1.5" thick, 18" tall vertical plate welded to it, with a bevel weld.  I'm pretty sure the top will bow toward the weld somewhere between 1/8" and 1/2".  I want to jig it correctly so that after the weld, the tip it is vertical +/- 1/16".
Thanks!!
RE: Calculate weld shrinkage?
It's going to bow a heck of a lot more than that.
Do you have access to both sides of the weld?  If so, use a double bevel and weld from both sides.
No I don't have access.  More than 1/2"?? Hmm... hence the need for some sort of calculation.
Realistically, there are too many variables to calculate.  I've seen a 5/8" plate bow 3/4" and break a strongback when welded with the GTAW process, and I regularly see 1" plates with backing bowed 1/2" when welded with 1/8" SMAW electrodes.  Your bevel geometry, welding process, and number of deposited weld passes will factor into your total shrinkage considerably.  Most of the estimates I see tossed around are gross underestimates.
The Design of Weldments by Blodgett has some very good information on design and distortion control all for $15.00.
https://ssl.lincolnelectric.com/lincoln/apdirect/item.asp?prodnum=DW&PID=16
You mention using a jig which is OK but strange things  happen on cooling. There is good point made here about using a jig and leaving the weldment attached and stress relieving the piece as one.
http://www.welding-advisers.com/Welding-distortion.html
Best bet is to tell the welder where you want it to end up.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Following up:
NR Mandel 21.1 worked well!  I decided to adjust it for steel (different CTE), and figured a 0.32" deflection.
We jigged it to compensate; after welding the plate was right on.  Thanks all for help!
And yes I am aware that the alignment of the planets was probably involved. =)
