Friction Value b/w Stainless Steel Clamp and Neoprene
Hi All :
I need to figure out the pull out load in an expansion joint. The joint consists of two aluminium pipe, with a 1" gap and covered with Ventglas (a heavy glass fabric double-coated with duPont's Neoprene(polychloroprene))and which is clamped at both ends with Stainless Steel Hose Clamps.
I was able to find out the pressure imposed by clamps, now I need to multiply that by the coefficient of friction to figure out axial load capacity. Where can I get an approximate value of friction coefficient b/w SS Clamp and Neoprene ?
Kapil,EWI
Kapil,EWI
RE: Friction Value b/w Stainless Steel Clamp and Neoprene
The problem gets more interesting as the hose slides enough to start compressing itself between the distal clamp and the hose bead, presence of which has been suggested in yet another discussion you have started.
Mike Halloran
Pembroke Pines, FL, USA
Take regular rubber hose (air line type?) make a 360 deg loop. This will remove any sliding forces in the system.
You can get the hose fitted with pipe ends and you can just thread the whole thing together.
Another method would to work in a "U" into the line that would allow the pipe to expand and contact. If you look at the plumbing in places like a chemical plant, refinery or the Alaskan pipe line you will see this done.
Use the "KISS" method whenever possible.
You can always use the inclined plane method and measure the coefficient yourself.
Charlie
www.facsco.com
