Plot labels - adjusting font size
hi,
I am quite new to Mathcad. i am using Mathcad to provide me with plots which i then import, via Visio, into MS Word.
My question is, is there any way to increase the label font size, without increasing the other text size? You will see from the attached file that the voltage levels are quite unclear - i am having to change them into tiff files, the turn them into jpegs, but in doing so the image seems to have lost its quality. is there anyway to import the directly from Mathcad? Or any way to maintain the quality?
Ben
Ben
RE: Plot labels - adjusting font size
Usually when I import Mcad into MS Office, I [ctrl-left click] the graph, "copy", then "paste special", and paste in as metafile.
Peter
I usually copy the data into Excel and plot in Excel.
TTFN
The conversion to jpeg is to bring the file size down (the final document contains maybe 14 of such images, and the resulting document size was far too large).
Assuming you're using Mcad 12,13, or 14 I agree with IRstuff that it is best to use something other than Mcad for graphing (Mcad 11 had very powerful graphing capabilities that were unfortunately dropped in Mcad 12).
If you do want to use Mcad graphs, one thing you can try is go to Format menu > Equation > Style Name > Constants > Modify. Then change the font properties. This will change the plot labels, unfortunately it will also change all the other constants in the worksheet though.
Peter
