Surface force/ pressure in custom direction
is it possible?
i'm trying to load a model in only one direction (strictly), but there is no option of specifying a vector for the pressure (it's just normal to surface). a force isn't good either (no surface contact).
is there anything else? would it be possible to set gravity for each part (there are two and a cohesive element in between) separately?
RE: Surface force/ pressure in custom direction
i am trying to fix the below (smaller) part so that i get accurate data on cohesive stress.
corus
