Multiple Display Styles in the Same Drawing View
Hello all,
Is there any way of changing the display style of a sub-assembly within a drawing? In a similar way to the "component line font" command, can you change one part or sub-assembly to be shaded with edges and leave the rest of the drawing view HLR?
RE: Multiple Display Styles in the Same Drawing View
-handleman, CSWP (The new, easy test)
