Copy custom properties from one part to another
I know there was a good macro to copy custom props from one part filr to another. I used it about a year ago. I cant find that now. I tried to serach in the following link too.
http://www.eng-tips.com/faqs.cfm?fid=1429
Can some one direct me.
BT
RE: Copy custom properties from one part to another
http://www.esoxrepublic.com/freeware/index.html
You can thank TheTick.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Thanks, Shag.  I wasn't quite vain enough to think that mine was the "good" macro he wanted.  I think that one still works, but is long overdue for an overhaul.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Tick,
Thank you. I am using CopyCustomInfo--Esox.swp. Its a great tool. Initially it wasnt working for me because I wasnt having it in the same directory as the parts.
When have them on the same folders, It just works fine, Thanks
BT
Thanks BluTurtle,
I have been using Esox copy macro for a couple years now.  But, since upgrading to 2010 sp2.1, the macro would crash the whole program.  I have been struggling to find a replacement.  But, your suggestion worked.  I put the swp file into the drawing directory and everything worked fine.
Thanks!
Thanks to Tick :), the Saviour.
~ BT
