Whalen method question
I was doing some reading on a method of developing bolt load for flanged joints, and I came upon a simplified procedure created by a fellow named Whalen. The book is "Handbook of Fluid Sealing" by Robert V. Brink, Daniel E. Czernik and Leslie A. Horve. The section is on page 3.9.
My question is this, in the description of this method, they offer two methods of getting bolt load, one by gasket seating stress, the other by hydrostatic end force, just a simplified version of the ASME BPVC guidelines.
However, this method goes on to say that the bolt load calculated by seating stress must be higher than the bolt load calculated by hydrostatic end force. If it is not, then, "gasket design must be changed, the gasket's area must be reduced, or the total bolt load must be increased."
It was my understanding that in BPVC, you just use the higher of the two, that makes sense to me. But it seems here its saying seating stress bolt load must always be higher than the hydrostatic calculation.
I have been trying to figure out a reason why it would say this, but I can't think of a good one. Can anyone explain why this might be the case?
Thanks everyone!
Thanks everyone!
RE: Whalen method question
Mike
To me it seems Whalen got it backwards. I would think you would always want a lower seating stress, so that way when you torque above and beyond it to resist hydrostatic loads, you don't have to worry about the gasket unseating.
I am curious how Whalen assigns a stress or load to the gasket.
The Code calculation uses a slighty different approach, the operating bolt load consisting of both the hydrostatic end force and a load on the gasket proportional to a multiple of the design pressure, the "m" value.
Code seating bolt load is found from the (somewhat fictional) "y" value, at zero pressure. The higher value of the two is used in further calculations.
Mike
Fb1 = Ag * y ; where Fb1 is required bolt load, Ag is gasket contact area, and y is required seating stress
Fb2 = K * P * Am ; where K is a safety factor from 1.2-4.0 depending on situation, P is operating or test pressure, whichever is higher and Am is gasket area which hydrostatic pressure acts on, which he says is generally mid-diameter
Whalen says that Fb1 should be greater than Fb2, if not redesign the gasket, reduce area or increase your bolt loads.
To me it sounds right that you just go with the higher force, and if its the bolt load to resist the end force, then that's fine, because its already higher than the seating force, so the gasket should still stay seated.
It doesn't seem necessary to do a redesign, or reduce area as Whalen says. This is where my confusion lies.
If bolting were selected per Fb2 then, ignoring the safety factor, at design pressure all the bolt load is taken by the end force, none is available to retain any gasket seating stress.
If Fb1 is the higher and bolting selected per it, then the difference between Fb1 and Fb2 is available to apply gasket seating stress at design pressure.
Mike
Could you give me some insight as to how I could redesign if Fb1 is not greater than Fb2, Whalen says "gasket design must be changed, the gasket's area must be reduced, or the total bolt load must be increased" What exactly does he mean by that?
At large NPS's like 84 I couldn't expect a ring style to be used to reduce area. It seems my only options are to swtich to a higher seating stress gasket or to just set a S.F. on my torque so I've applied enough, or set torque to 90% yield on my bolts. Selecting a higher seating stress gasket seems a bit counterintuitive.
As discussed previously Code supplies values for gasket seating stress and bolt stress, so that you know what values to use. Does Whalen offer values, or is that up to the designer?
Mike
In my book, it does not mention Whalen giving any values for gasket seating stress or bolt stress, it just gives those two equations and a brief explanation of appropriate safety factors.
Since these are standardized flanges, I can not make the bolts bigger, or add more bolts, it seems my only option would be to put more stress on them, probably 75-90% yield.
Can you clarify making the gasket "narrower" do you mean reduce its width? With standard off the shelf full-faced I don't think that's possible.
Actual, applied bolt stresses are well known to be above, and often far above, Code allowables used in flange design rules.
You might contact the gasket manufacturer for a recommended stress and get a bolt load from that, or you might get hold of ASME PCC-1.
Mike
The math itself using Whalen is just quite simple and intuitive, its only when he mentions re-designing a gasket does his method get abstruse.
I have read PCC-1 and use it frequently, its an invaluable resource, however it doesn't really explain its values too well, nor have I found it gets read as much as it needs to.
