num2string command problem
I would like to export the result from my calculation in Mathcad to file for use in another software. But I need a special format of exported values.
In an attached file I enter a value h0 for calculation, but I need the format of it for export with use of num2string command as shown in h1.
Any input appreciated.
RE: num2string command problem
...yes...everything goes if you know the way...This is exactly what I want. Thank you !!! I have never use these scripts, but it looks like it is a very powerfull tool. It motivate me to study them to use for another problems. Thank you again for that ! And a star for you.
No worries.   Thanks.
