Weight calculation
Weight calculation
Weight calculation
Hi!
Running NX 5.0.5.3 under TC 2005
We would like to have the weight of the part or assembly written on the drawing and have it associative so changes to the part/assembly reflects in the weight.
However i do not seem to find the attribut for the mass showed under "Display Part Properties" Weight tab if a would like to add it as a text. But when adding a partlist I gain access to the $MASS attribute however now the mass/weight is displayd in metric g not kg.
Ideas anyone?
BR Martin
RE: Weight calculation
A Part List can do it but you may have to change the field variable from <W$=@$MASS> to <W$=@$MASS>*1000000
Other ways include taking a body measurement and then using an associative note.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Thanks! The Part List *1000000 was something I did think of.
With "Associative Note" do you mean Text->Text Editor-> Relationship Tab-> Object Attribute?
Would that also work if I was to add it to a Drawing Template? (We use Master model concept) or do I need to manually add it to the drawing? The numbers in the attribute "<W!450381@MASS>" seem to change depending on the object a choose..
Best Regards
Martin
Yes that was what I meant
Sorry I never spelled it out for you. I was being brief because this entire correspondence took place during my sitting in on a three way conference call, Australia, US & Canada. You have to love VOIP!
Best Regards
Hudson
www.jamb.com.au
Yep VOIP is sweet! smile
Bacck to the subject. You missed my second question regarding adding a object attribute to a drawing template...
Best Regards
Martin
The answer was that I regularly use this in most of my templates. I also have several templates for customers in heavy industries who like their masses in kg.
Best Regards
Hudson
www.jamb.com.au
