Blocked well
Blocked well
I'm thinking of ways to clear a blocked well. The well should be 107 feet, and there was 90 feet of pipe pulled 20 days ago, but the sounder is only showing 63 feet. This has been verified by the hole camera. On camera you can see the pin hit the block and it seems to be very solid.
How would you clear a blocked well pipe?
-use a smaller pipe (with teeth cut into the end) inside the well pipe to try and grind the blockage
-use high pressusre water to try and dislodge some stuff
-shoot it with a gun
-your ideas here
-your ideas here
RE: Blocked well
RE: Blocked well
It is difficult to provide good advice without correct knowledge of the process followed. It seems you had the casing removed, hence you may start as anew with whatever the method that ensures you in the end will have the fruit of your effort.
RE: Blocked well
What is the well diameter?
What type of formation is the well drilled into?
Is the well cased?
If the formation has collapsed, you may have to case and grout in the location of the collapse.
