Average Annual Thunderstorm days
Where can I find average annual thunderstorm days for lightning protection study in texas?
RE: Average Annual Thunderstorm days
Phovnanian,
Thanks for the link. It is really difficult to see any information on the map you pointed out. I hope others might be able to guide me to some better maps
Go to www.vaisala.com and drill down into the weather measurement category / then lightning detection category / then data and archive reports.
There are seasonal and multi-year lightning activity studies with really good geographic selection criteria.
Vaisala is the company that owns the National Lightning Detection Network that NOAA and all the weather bureaus use.
Good on ya!
Goober Dave
IEEE Std 998, IEEE Guide for Direct Lightning Stroke Shielding of Substations has a thunderstorm day map of the USA.  There is also a thunderstorm day map of the USA at http://www.lightningsafety.com/nlsi_info/lightningmaps/US_TDightning.html and one at http://www.srh.noaa.gov/srh/jetstream/tstorms/tstorms_intro.htm.  These are all different.
There is also a flash density map at http://www.lightningsafety.com/nlsi_info/lightningmaps/US_FD_Lightning.pdf
Thank you all for your response.
I wasn't sure if the map shown in IEEE Std 998 is still usable and wanted to see what sources or links others were using to figure lightning flash density and average annual thunderstorm days etc for their shielding studies.
If you look up Thompson Lightning Protection, inc.  at www.TlpInc.com you will find a risk assessment link that provides an isoceraunic map of the US and also the methodology for the lightning risk assesment calculation.
EEJaime
Contact a TX NOAA office, ask for the Warning Coordinator Meteorologist. It is his job to give you what you need.
