Pipe, Expansion Joint, Friction Force, Clamp
Hi :
An Expansion Joint, joining two pieces of Aluminium pipe is wrapped around by Ventglas. The Ventglas is clamped tightly at the ends using a Two Stainless Steel Clamps.
Now I need to determine the friction forces occuring which restricts the axial movement. How do I determine the friction forces. I have the torque value of the clamp.
Kapil ,EWI
Kapil ,EWI
RE: Pipe, Expansion Joint, Friction Force, Clamp
