repair/re-associate broken links
I'm hoping someone has a quick answer to this.
NX4 seems to let users create WAVE linked geometry without the WAVE license, but I have yet found a way to repair/re-associate a broken link.
Essentially I created some linked bodies, the customer sent new models. I replaced these models (model is different, so I can't just roll the revision on the customer model). I have to break the links. I add the new customer models as new components, and now I want to re-link the customer model to the solid bodies generated/edited earlier.
RE: repair/re-associate broken links
As for how does one 're-parent' (re-link) a broken link, just make the Component which contains the broken link the Work Part, then from the Part Navigator, double-click the 'Linked Body/Face/Edge/...' feature, select your replacement referenced object, hit OK and you should be back in business.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
That definitely helped. I must not be looking/searching the right terminology in the help. I could not find this anywhere.
Thanks again.
