load limits of steel I beam
I am installing a steel I beam (16x26x23') and it is spanning 22' in ,my garage. The building inspector needs to know the load calculations for this beam how do I find this out?
RE: load limits of steel I beam
Kevsdoll,
If you are not qualified and capable of doing those calculations yourself, then you need to pay a professional.
I agree with Austim. Try using the yellow pages to find a licensed Structural Engineer in your area to provide the required calculations.
I agree with the others.  Details are required to answer this question, and since none are supplied, it confirms your over your head. Although it can be a rather simple question for someone familiar with your local building code and structural design, it can be quite dangerous for one not familiar to try.  Are you a gambler?  Would you let nurse or a GP who has a vague idea of how an operation goes to do a complex operation on you?  No, I dont think so.  Get some real help.
