Rigid-Ended Beam Element
Hi Guys,
I am sure you've come across coupled shearwalls. Does anybody have any idea how to model spandrel beams which couples the shearwalls by use of Rigid-Ended Beam Elements?
many thanks,
Sam
RE: Rigid-Ended Beam Element
Kellnerp,
ETABS specificaly for structural engineering modelling . But, any general idea would be hlepful as well.
thanks.
I'm not familiar with ETABS, but generally this kind of information might be in the help files.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
"Node news is good news."
If the program allows in-plane moments then a normal beam element could be used, otherwise you might create one almost weightless material of the same stiffness than the coupling beams and make it enter the coupled shearwalls; it will distort somewhat the stiffness but ***might*** be tolerable for practical use; that is, you would model the link RC and what entering the walls weightless.
