tension compression splice
What's the difference between a splice, a tension splice and a compression splice?
The plans I'm looking at says use 30 bar dia. But then, right below it, it says to use a Class B tension splice in accordance with ACI 318.
The typical detail says "splice top and bottom bars as shown" It's nothing out of the ordinary. I have a multi span grade beam supported by drilled piers. Top bars lap at midspan and bottom bars lap at support.
So do I apply the 30 bar dia lap or the tension class B lap? I looked thru the ACI manual and it doesnt give me a definition nor does it tell me when to apply one or the other.
RE: tension compression splice
I would use the specified Class B splice as that may be (probably will be) longer than the 30 bar diameters.
A splice is a way to take two separate bars and connect them or overlap them such that they work equivalent to a single bar across a specified location, such as a joint.
A tension splice is simply a splice that is dealing with bars in tension.
A compression splice is simply a splice that deals with bars in compression.
Splices can be overlapped bars (per ACI chapter 12) or mechanical connectors such as this: http://www.erico.com/products.asp?folderid=45
Lap splices are prohibited for most uses of bars larger than No. 11 by ACI 318-08 paragraph 12.14.2.1.
318-08 section 12.15.1 specifies that Class B laps are 30% longer than Class A splices.
Section 12.15.2 specifies that Class B is required except in certain instances.
In current practice, some engineers are permitting splices where previously prohibited, based on the thinking that Class B splices assure that all reinforcing is fully developed in all sections beyond the initial development length at discontinuous ends.
