1000 DEG F on CS A53 Pipe
Is it acceptable to use A53 CS pipe for a generator exhaust at approx. 1000 F or some type of alloy has to be used?
Thank you
Thank you
1000 DEG F on CS A53 Pipe1000 DEG F on CS A53 Pipe(OP)
Thank you Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: 1000 DEG F on CS A53 Pipe
Well it was originally schedule 40. However, they installed schedule 10 and I was asked to verify the stresses at the supports for the new thickness. Schedule 10 fails and stiffening is required. B31.1 does not even show an allowable for that temperature. Is there any other source that we can use to detemrine the allowable if any left at that temperature?
Thank you
Carbon steel will last for a while.....
But engine exhausts are subject to internal/external corrosion as well as high temperatures.
Check the exhaust system under your vehicle.....
Its probably 430 or 316 Stainless steel
http://www.ksdirect.net/general_products_info.html
http://bo
-MJC
B31.3 does not prohibit the use of A53-B at 1000°, but the allowable drops to 2.5ksi.
You can also look in Section II Part D.
SP
You should have stayed with Journey....
ASME B31.3 discourages use of carbon steel above 800F through use of a "single bar" in the Basic Material Allowable table.
The bar refers to a note at the end of the table.
"Dont stop Beliveing" that the Code discourages this kind of high temperature usage...
-MJC
B31.3-2006 is all I have handy, and it's just a single bar at 800 with no double bar to be found.
So, I still stand by my "does not prohibit" statement.
If sigma needs anything more comprehensive than a hint to go look at B31.3 or Sec2... well, a free message board probably isn't the place to get it. Even us burned out rock stars turned engineers need some business nowadays.
-SP
