ISO Lock washer?
ISO Lock washer?
ISO Lock washer?
Sorry I'm a little new, I suppose.
Just wondering if there's such thing as an ISO lock washer, and if there is, what it's ## is. In Solidworks toolbox, there is no such thing. Our eng. dept. uses ISO standard hardware, except lock washers... but perhaps Solidworks is just missing it?
RE: ISO Lock washer?
lorvan,
   What does your supplier send you?  As far as I can tell, most metric hardware here in Canada is DIN, not ISO.
   If you search Eng-Tips for information on lock washers, you may find a simpler resolution to your problem.  The consensus seems to be that they do not work.  Use a flat washer if you can, and make sure the screw is torqued down properly.
               JHG
Look for DIN 127. ISO will in most cases be the same. I am not aware of any ISO spec for Lock washers.
Not really sure what you're asking for. Are you looking for a Solidworks model for a lock washer? Or a lock washer to ISO standards?
I don't know of any ISO specs; and neither do your engineering department. Would it not be wiser to find out what they do use?
While we rarely use lock washers, DIN 127 as Jeurgen suggests, would be worthwhile looking at.
The decades-old European vehicles I have worked on typically use those thin 2 wave "lock" washers, and only on non-structural components like magneto covers. Sometimes split or star washers (shiver) on electrical connections. Never on stressed components like con-rods, main bearing caps, or suspension parts.
