3-ply Laminated Glass in E1300
How do I apply the specifications of E1300 for laminated glass with 3 plies of glass and 2 interlayers? Can I simply add all layers together and use the equivalent minimum thickness as in 3.2.3.2 and extrapolate the values in Table 4? The design I'm checking uses 3-10mm plies with 2-1.52mm PVB interlayers.
