PropertyManager API VB.net
Let me try this again.
I have a program I am writing and I have very little experience with vb.net. I am trying to figure out how to bring information from a textbox in the property manager, using the swPropertyManagerPageControlType_e.swControlType_Textbox command.
RE: PropertyManager API VB.net
swPropertyManagerPageControlType_e.swControlType_Textbox is not a command.  It is 5.
What have you managed to achieve so far?  If you have created controls on a PMP, you must have used the command AddControl.  This command returns a PropertyManagerPageControl object. You can query this object for its Text property.
-handleman, CSWP (The new, easy test)
Yes, I Have been able to create a page, and everything looks great. How do I query the text property.
OK.  You used the AddControl method, right?  That line should look something like
myControl = myPMPpage.AddControl(some arguments).
To get the text, use
SomeStringVariable = myControl.Text
Thank you. I have been able to get it now.
You got me into the right direction. I was able to retrieve the data as long I was in the same module. So my final line ended up as
BSTR = UserPMPage.textbox1.text
I'm relatively new to all this as well.  I need to get the data from a PMP, but with a small catch (maybe)!
I'm creating a "product configurator" using the PMP.  I've got the PMP layed out, it looks great.  I don't want any code to execute until the user clicks OK.  So my main sub starts the PMP, and makes sure the user has selected the appropriate component.
Then, in the PMP event handler class OnClose event, I have a call to a second sub in the same module as the main.  How can I get the inputs from the PMP into the second sub?
